Its ****!
Rich B
http://www.madisound.com/catalog/product_info.php?products_id=8700
It's a driver strictly intended for music, fellas. Who gives a shit about how much power it can take? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif A nice low inductance, low moving mass, with a nice soft spider, and four breaks in the spider to get rid of the resonant behavior and subsequently the character it would otherwise add. Genius.
so if this sub is intended for music, what frequencies will it play? music implies a broad range of frequencies not 100hz and below. i'm sure you aimed this post at me as I'm the one who brought up the power handling. i was just pointing out the low power handling for a sub. i highly doubt that this sub is worth the $150+ price tag that it sports.
I wasn't aiming at anyone in particular, just contributing to the conversation. But since you asked, I'll first point out to you that it is not a subwoofer at all. It's a woofer, and there is a difference. It could be used as a subwoofer but it would most likely be used in a three-way full range setup for 2-channel home audio. Music does imply a broad frequency range which is why they went through the trouble of putting copper in the motor to keep inductance down and it's also why everything about this driver is to facilitate a musical presentation, from the curvilinear profile cone with the flat edges on the perimeter to break up the modal behavior within it, to the open basket design to keep it from being a large obstruction to the rear wave, and everything in between. As I stated before they even placed breaks in the spider to prevent it from being a significant second source for resonance and character.
This driver, once the peak at 800Hz is addressed with a very simple notch filter, could be used right up to 1KHz without any change in it's power response up to 30* off-axis, which is very impressive for a 10", and would allow for a very flexible filter design between it and the midrange driver it may be partnered with. Moving mass is a mere 98 grams and it still has an Fs of 23Hz which may give you an idea of how soft the spider is. A soft spider lets the details of music through at even the quietest listening levels.
Neo, copper, aluminum, wood, rubber, hand built... I could keep going but I feel like I'm rambling and I'm sure others do too. This driver is a gem and a bargain at $175.
Edit* I just noticed that the spider quadrants are alternating for the orientation of the convolutions in the fabric. Even better. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Rich B
Rich B
*under the rainbow*
ciaonzo
Mike Mccabe
