mrawesome
so you hear hype about a 1 ohm or even .5 ohm system. but why does that crap matter? If your system is 2 ohms at 2000 watts or 1 ohm at 2000 watts, are they not the same? I'm curious because I'm deciding whether to buy the 2 ohm dual voice coil or 4 ohm dual voice coil version of the same subwoofer, and also how to wire it. Should I do a 1 ohm stable monoblock with 2 ohm coils both in parallel, giving the least impedance? or use a two channel amp, with each channel on a coil? or use the two channel amp bridged to the dual 4 ohm coils in parallel?
