Is this the right idea?
cajun_duck
I will be hooking up front stage only using comps. From the back of my HU, do I use a 2-male to 1-female y-adapter from the front and rear pre-amp outputs? My HU has both front and rear plus sub out. Today I am having one of those "you learn something new everyday" days. I didn't know before that when using 2 or more amps that you have to fuse and relay the remote line. Last time I had a multi-amp install I just jumped the remote from 1 amp to the other.
you can get away with daisy chaining remote wire to amps when using only 2 or 3 most of the time. anything more and a relay is a good idea. If your only running a front stage then just use the front out's on the head unit. why are you trying to use both the front an rear if your only running fronts?
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif:confused://content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif, good question!
My reasoning for this questions is that sometimes there is a song where when recorded, to give it a little bit of an effect, they only record on the left or right or front or back for background fill.
cajun_duck
cajun_duck
Houma, LA
cajun_duck
