Is this mutlimeter ok to buy
I have a Fluke. It cost me more than what most would want to spend on a meter but it does everything I need and has never failed. It also won't cause me to get electrocuted in the amp function or when working on household current.
I have used my $25 meter on cars, at home and on 220 lines at work. It has not failed yet.
I think it the only differences will be accuracy(minimal) and lifespan of the meter(build quality such as the knob)
THIS is all you need in order do 95% of things you will ever do with electricity if you have to ask the question which one to buy. Now if you were an electrician by trade, you would not be asking this type of question, because you would already own a Fluke.
If you use a cheap meter to work on AC circuits you are asking for trouble. The main reason is safety. For instance, if you have a cheap meter and have the wrong setting your meter can actually blow up in your hand.
There is a safety cert that protects against this kind of thing. I can't remember the name (IP67 maybe?), but it comes standard on all Flukes. Basically if you have a certified meter and you have the wrong setting it will just blow a fuse instead of exploding.
But it won't matter for DC in car audio.
In my link above it says:
Fused circuit with diode protection
750 VAC or 1000 VDC max. input
If someone is testing over 750 VAC, then I would assume they have the correct equipment. And the $5 DMM is fused for protection.
We had a maintenance guy get burns on his hand from testing 120vac. He forgot the meter was set for DCmA (I think?) and he was using a cheap Craftsman meter. The meter blew up and he had to go to the hospital.
After that I had to catalog all the meters in the plant to make sure they they all met the OSHA Arcflash safety requirements. Again I don't remember the specific standard (CAT #?) but basically all newer Flukes come with that built in.
You can test your meter if you are feeling lucky. Just set it to DCmA or Ohms and put the leads to 120AC. If all you do is blow a fuse then I would be very surprised. Your meter may not explode like the Craftsman but I would guess it would smoke alot and be unrepairable.
http://ecmweb.com/mag/electric_meter_safety_measure/
Cheap meters are great, I have several. But I'm just saying don't use them on AC unless you are really careful.
buy a nice meter. i have bought 2 cheap one and they both **** ***. i have a craftsman one and it is ok i dont use it alot because i use my power probe3 for everything at work. but i am going to be buyin a NICE DMM probly a fluke. well worth the money
OK, can we put this issue to bed with a sticky or something?
We all know that Fluke makes the BEST meters in the world. No one will ever question that fact. If you are going to work on multiple electrical projects, they are worth the investment.
Now what most people on these forums need is not a $100+ DMM. They are only trying to check simple DC voltages, check the resistance of their speakers, and possibly set the gains on their amps. The $5 (or less) cheapo DMM from Harbor Freight will do them just fine.
Not everyone needs to be pushed into a $100 DMM that will be used only a couple of times ever.
riddla
riddla
nf
01sugar2
