Is This Amp Worth It?
ewoevo
I found a Rockford Fosgate T10001D for sale locally for $100. It needs a fuse, but works fine. I'm thinking of getting it to run one of my RE HC-12s (the other one will be run by an Avionixx 1200.2). Let me know what you guys think. I know, I prefer to have matching amps, but I can't find another Avionixx amp and its for my son's car, so he doesn't care.
Sounds like a good deal, make sure it works!
Just don't run each sub off of a different amp like that, subs would probably be out of phase.....Use the most powerful amp on them.
Well, my subs are dual 2 ohm, so I'm limited to either a 2 ohm or .5 ohm load (I know I could run them at 8 ohm, but what's the point). I know its not ideal to run each sub on a different amp, but I can match their output pretty closely by adjusting the gains. They put out similar power, so it shouldn't be to much different.
ewoevo
ewoevo
FL Panhandle
ewoevo
