is this amp even close to what they say?
budgetkiller
Okay, so my friend asks me how much 4ga wiring will handle. I sent him a chart and asked what kind of amp he wants to run. He said a Demon 4000w. So I Google it and find out it's made by Power Acoustics. Okay, so it's obviously obsurdly overrated. So I find it on their website and they claim 2k rms at 1 ohm. I was surprised. Then I saw it only has 2 gauge inputs (might have even been four). Shouldn't ANY amp running anything near 2k watts have zero gauge inputs? And is this thing actually anything close to a 2k amp or is power acoustik not cea compliant?
Liklely around 1200ish watts rms.
With power acoustik classD amps, a good guess at 1ohm power is to look at the 'rated' 4ohm power. That is usually a realistic rating for the 1ohm output.
the wiring input has nothing to do with an amps output capability's, my older memphis mc2000d was a 2400w rms watt amp with 4g power inputs and it did every bit of it's rated power.
4x35a 140a yep about 1200
Didn't know that. Leanrned something new today. I guess my question is why would they have such small inputs with that kind of power. Conceivably, if you were to try to run that and needed a 12 foot power supply you wouldn't be able to hook one up to meet what it needs right? Is this because they plan on you adding a second battery and know you won't need a wire that long or are you just supposed to use an adapter if that happens?
budgetkiller
budgetkiller
Chicago
budgetkiller
