paintballer
hey guys. I set my gains on my Mono class D amplifier for my subwoofers with a DMM, and i followed the voltage formula, V=Squareroot(RMS Wattage X Resistence).
http://www.circuitcity.com/ssm/Specifications-of-MTX-Dual-12-1350W-Subwoofers-Enclosure-TCE4512X2D/sem/rpsm/oid/147568/rpem/ccd/productDetailSpecification.do#tabs
Those are my subs and my amp is here
http://www.alpine-usa.com/en/products/product.php?model=MRP-M450&lang=en&tab=F
The lowest RMS wattage was of the amp, so i plugged the numbers in. I just figured the sub box was running at 2 ohms. i got
V=sqrt(400RMS X 2Ohms) = 28.3 volts, which then i got with the DMM in AC current while turning up the gain with the subwoofer volume on the deck at max (15). i actually put the gaina t about 27, just to be safe.
But here is the problem. Should I have plugged in 4 OHms into the equation instead of 2 Ohms. I dont know what my subs are runing at. There is only 1 input terminal on the prebuilt sub box, but there are two subs. So i dont know if combined they are running at 4 ohms, or was putting 2 ohms into the equation correct?
If the sub prebuilt box is running at the 4 Ohms, then the volts would 40, right? Then i would have to raise the gain again. When i did the test i used a 80 hz test tone and the sub volume was at a max of 15 on my alpine deck. Is that alright. The LPF is on like 90 or 100 HZ
Thanks for the help guys
