Is there such a product?
Flipx99
Violator of Terms
This is what I am looking for and I will describe the best I can...
Pretend you had a piece of plexiglass that has pretty stiff, yet could conform to groves and less than 1/8" thick, and be able to be adhered to mdf.
What I am trying to do is fill in the area around where i am placing a ring. The hole in the door is too wide. I will have to cut some around the top, but in a left to right dimension, it is wider than the ring. I am looking for something I can place under the ring that will conform to all the edges and still be somewhat stiff.
My initial thoughts are to place a sheet of plexiglass with a whole cutout with dimensions slightly under the hole in the door....then use deadener on both sides to make sure it is sealed.
Is this a good method...would pics be better to describe what I am trying to do? Does such a product exist?
I would go this route but using hardboard instead of plexi. It's cheaper and easier to cut. Then you can glue it with Titebond to the MDF.
Flipx99
Violator of Terms
Flipx99
Building 100
CrazedCat
BP1Fanatic
BP1Fanatic
