is there a big differance in power wires
I partially agree with BJ. The Knu Flex and Kicker hyperflex is, IMO, no different. They both have the same flexability. Ther Tsunami is less flexable but I wouldn't say it's "not flexable at all". It's the same, just as flexable as any other wire that isn't Knu Flex or Hyperflex.
The CCA wire can't carry as much current but is more than sufficient for the majority of people.
Nothing other than being a little larger to carry the same amount of current and being less flexible.
So the Kolossus 0/1 I noticed can handle about 300A according to Knu, whereas the KLM 0/1 can handle 200A-250A, too bad they don't offer the Kolossus 0/1 in a wiring kit.
I'm gonna be running about 2500W total fuse rating of both amps is 270, so I'm thinking I might NEED the Kolossus's higher rating //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Tinned wire has more resistance.. also the fancey transparent jackets you see in car audio are made of plasticized PVC.. AKA shitty jacket..
better off with a quality wire that uses strait up copper and a neoprene jacket.. such as welding cable..
Fuse rating has no bearing on how much current the amps actually draw.
fatboyracing
fatboyracing
Owensboro KY
helotaxi
