is the orion 6002 1 ohm stable?
traksta15
I love lamp.
I need an amp that can push my boston acoustic z6's, I have an orion 3002 but it's not going to be enough to push them. Im really wanting to have matching amps (to match my orion 1200d sub amp), only problem is; If I can find an orion 6002 will it be able to drop below 2 ohms (1.5 ohms) to push them? Thanks in advance guys!!!
I have an 03 silverado ex cab, stock alt, yellow top optima and im doing the big 3, all wiring is 1/0. Is that strong enough? Do you guys think the 6002 can handle under 2 ohms?
Ive owned the 4002, 8002, and (2) 1200ds, but I never dropped the 4002 and the 8002 below 2ohms. I think running it at 1.5ohms will be fine, Ive run other amps similar to it like that and they worked fine.
Amp will prob pull a little bit more and run a little warmer but I think you will be fine.
traksta15
I love lamp.
traksta15
Mcalester, Ok
traksta15
