shallowrockford
Ok so I'm working with VERY limited space as I am fitting a 10" sub under the seat in my boat. The biggest I could make the box was 19" L x 13" W x 5" H. I used 3/4" MDF so subtract 1.5" from that. The sub I bought is a shallow one.
Rockford Fosgate R2 R2SD4-10
Specifications:
Nominal Impedance: Dual 4-Ohm
Voice Coil Diameter: 2" (50mm)
Magnet Weight: 45 oz. (1.28kg)
Speaker Connector: Dual 12-Gauge Compression
Re: 6.60-Ohms
Le: 4.2mH
Qms: 7.00
Qes: 0.81
Qts: 0.73
Vas: 21.7 (Liters)
Sd: 333 (cm2)
Xmax: 8.0mm
Frequency: 39.3Hz
Sound Pressure Level (SPL): 82 (dB at 1w/1m)
Cutout Diameter: 9.125 Inches (232 mm)
Mounting Depth: 3.417 Inches (86.8 mm)
Woofer Displacement: 0.037 Cubic Feet (1.05 Liters)
Will this sub work well with my sealed box?
Specifications:
Re: 6.60-Ohms
Le: 4.2mH
Qms: 7.00
Qes: 0.81
Qts: 0.73
Vas: 21.7 (Liters)
Sd: 333 (cm2)
Xmax: 8.0mm
Frequency: 39.3Hz
