is it possible
i dont see this beeing possible because an amp sends out a signal hpf or lpf on all channels available, 4 channles may be different, then again depending on how good the 4 channle amp is also makes a difference on all the settings available
HU's typically send the same signal out of all the outputs, at least mine does.
If you buy the right 4channel you have control over all the channels filters. Most do that.
Also depending on your headunit, you may be able to control that through the Head Unit, I can on mine.
It's possible man, trust me, people do it all the time.
Find the right amp //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
If you want a budget amp with decent contorl go Hifonics
if you don't know the answer don't guess at it. it shows your stupidity
just make sure the bridged 3 &4 channels see an 8 ohm load if channels 1 & 2 are seeying 4 ohm
you're an idiot
yes you can do what you are asking./thread unless you need to know how as well
thinking about running these on channel 1 and 2
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=6201
and running this bridged on channel 3 and 4
http://www.crutchfield.com/p_136S110T12/JL-Audio-CS110TG-W1v2.html?tp=112
and with this amp
http://www.crutchfield.com/p_500MRPF600/Alpine-MRP-F600.html?showAll=N&tp=115
let me know if there are better options... this is going into a regular cab truck btw (f-150)
whats a good wiring kit to hook all this up?
gnatnoop
gnatnoop
ca
gnatnoop
