is it possible to make a ported box?
damien02
well! at this time i'm going to make a seald box for my two JL 12w6v2 ... my amp is a jl 1000/1 .
but in case i could, i would like better make a ported box (tune to 32.2hz) !
so maximum dimensions in my trunk to make it are:
29,5in (width) X 14,2in (Height) X 18in (depth)
so if it is possible with this volume to make a ported box....i can pay plans with paypal. //content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif
thanks a lot
thanks for your answer
specs for one 12w6v2 are:
Free Air Resonance (Fs): 25.0 Hz
Electrical “Q” (Qes): 0.480
Mechanical “Q” (Qms): 7.100
Total Speaker “Q” (Qts): 0.450
Equivalent Compliance (Vas): 2.82 cu. ft. / 79.9 liters
One-Way, Linear Excursion (Xmax)*: 0.65 in. / 16.5 mm
Reference Efficiency (no): 0.250%
Efficiency (1W/1m)**: 85.9 dB SPL
Effective Piston Area (Sd): 77.8 sq. in. / 0.0502 sq. m.
DC Resistance (Re): 6.75 ohm***
Nominal Impedance (Znom): Dual 4 ohm
Thermal Power Handling (Pt): 400W
Driver Displacement: 0.090 cu. ft. / 2.5 liters
Net Weight: 19.4 lbs. / 8.8 kg
hope it's good...
yes its possible, that would give you about 3.5 cubes before port and woofer displacement.
what kind of air space does your woofer need in a ported box?
3.5 cubes before displacements is not very big for two twelves. he is going to be down to 2.5-3 cubes after displacements
jl audio give 1.50 cu. ft./each sub after displacements... hope will help you
ahhh, yeah, i just skimmed through and saw jl w6, didnt catch that there were two of them. god catch //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
yeah, go sealed. not enough room for both of them plus port.
thanks all to study my question //content.invisioncic.com/y282845/emoticons/thankyou.gif.5451126d09e870f796f50c3a4dd5acd7.gif ....i'll go sealed
damien02
damien02
France
damien02
vegang
vegang
