is it okay to over amp a subwoofer
Steveopevo
I get so many conflicting answers on this that it has left me still confused. I will be buying a 12" Boston G2 subwoofer that is rated at 300 watts rms. Some have said get a 400 watt rms amp and keep the gain seting low and this will keep the amp cool. others say stay under 300 watts because the gain control does not lower the wattage output of an amp. please help clear this up for me so I don't buy the wrong amp
its a good thing to have an amp that puts out more power. reasons being, if you want to upgrade later on, you have the power todo so without buying another amp. also, an amp that can do more power then the sub can take can allow you to run at higher ohms making it better for the amp and I feelthat it can run more efficient. so you can send a good signal to your sub(s)
whats kicking my a$$ is that others reject this philosophy
The best option is to buy the larger amp. Like money, it's usually better to have extra than just enough or not enough amplifier power. The only voice of reason would be that the larger amp would normally cost more up front. To offset the extra cost, you could go for a used amp.
I cant see any real negative reason for it not being a good idea. there is no right or wrong answer. you can match power for power and still have a good set up. You can also have a more powerful amp and also be good with that. A lot has to do with the gain. Sending good un clippe signals to your sub is always the better option in my opinion! lol
im running about 1000rms on a 600rms sub
its an Re SE and it takes it fine, no bottoming out, no wierd sounds
100rms over will be ok
your amp is not constantly putting out 400rms, RMS is the average.
is that before of after independence rise
Steveopevo
Steveopevo
Silver Spring, MD
quins90lac
