RAM_Designs
SketchUp Master
exactly.
that
what
Maybe you should explain your thoughts fully if you want people to follow them the way you intended...i meant.
exactly.
that
what
It depends. I was only doing it for shows, so I would disconnect the alty from the main battery. Basically, the van would run off the under hood battery alone. I had a G31 under the hood, so run time was long. I actually forgot to reconnect after a show one night and made it 100 miles w/ the headlights on without a significant drain.Saying that the audio will run at 22V and the rest of the car at 12V is wrong. The voltage that the alt is running at is the voltage that the entire car's electronics will see...
I didn't think that we were talking about special instances where the alty would be disconnected from the main battery(although I good idea on your part). I figured we were talking about everyday daily driving situations.It depends. I was only doing it for shows, so I would disconnect the alty from the main battery. Basically, the van would run off the under hood battery alone. I had a G31 under the hood, so run time was long. I actually forgot to reconnect after a show one night and made it 100 miles w/ the headlights on without a significant drain.
I've seen a few, the most notably being Hoe Problems. I'll see if I can find some others.Maybe 10 years ago they were...nowadays 99% use ported or 6th order BP boxes for spl...
I'm not saying there aren't some loud sealed cars, but 99%+ of the time a properly designed ported or BP box will trump a sealed box with ease...
lol yup, biggest baddest cheater amps ever lol. I think nick shouldve called them the 150.1 killersdoubt it. I've seen the 20.1's take 22V at Meca finals '04.....
That amp must have had a customized power supply.doubt it. I've seen the 20.1's take 22V at Meca finals '04.....
Also, any 12" MTX would be just OK, nothing too great even from 9500s. Type Rs can be just as good.I was up a Auto advance and im bumping my type arrrrhhhhh's then this older guy comes up to me like man i can have you stuff thumpin to where anyone that pulls up next to you have their ears thumping.
He said something about he can get me thumping like so with
2 MTX 12's 1000w RMS a piece.
250amp alternator
something like this voltage thingy so you can turn the knob up to 22volts.
and he said he onlu fux with a class d amps that can do 22v. He said he can get 3000w RMS from 1000w or 1500w mtx thunder class d 22v amp.
O and by the way he said he runs/wires the amp to .25 ohm. thats 1/4 of 1 ohm.
Is this guy full of it or what?
In 2004 there wasn't a voltage limit in any classes. I'm not saying it's not dangerous, but it can be done for short periods of time on some amps. The regulator was set at 22v and even Nick couldn't believe they didn't blow smoke.That amp must have had a customized power supply.Most components used in the power supply have voltage limits. Caps are important here. In switch mode power supplies the voltage inside the amp is changed to AC and then raised very high. The DC input voltage could drive this voltage higher if the DC was raised and could raise it beyond the designed limits.
The basic automotive environment can have a voltage range of 10.5 to 16.8 volts. So amps are designed to work within this range. For protection purposes the range is always a little higher and a little lower. So some amps can have a range of up to 9.5v to 19v.
If you create an amp with a greater range or set the range higher, it will result in a less consistant and less efficient amp. In other words, if an amp is set to work at 22v, it could blow with under voltage and under voltage on an amp like that could be 13v.
Also, even 16v batteries will have their cells cooked with anything charging that high.
So a 22v setup at MECA Finals seems highly unlikely, They would have to have made custom batteries and would have to have modified the power supply of their amps. An adjustable voltage regulator for the alternator will easily do this though.
MECA does have an unlimited voltage rule in some higher classes, most other orgs limit voltage to 18v.
I could be wrong, it just seems unlikely to me.
