statonburrell
the saz1000 will put out around 1200 at a true 1 ohm loadNow I am so confused... should I keep or sell my SAZ-1000d to get the SAE-1200 v.2 amp?
the sae1200d will put out around 1500 at a true 1 ohm load
If you decide to run the amps under a 1 ohm load, stick with the 1000d, if you plan on staying around 1 ohm or over stick with the 1200d. Also another thing to consider is the build quality. The saz line is made in Korea which is known for having higher build quality standards. The sae is made in china and tends to have not as good of a build quality. I think the saz line also has some internal "beefing up" compared to the sae line which makes them more durable, etc. The saz line also has it's own specific boards different from any other company. the sae line i believe is not like this.
