Is a dual use for my rear channels possible?
  • 1
JakeJB
Utah
OK, so here is a little background to help explain my question. Hello everyone btw...
My truck is an F150. I am installing an Infinity Reference 6x8 in each door, replacing the factory front tweeters with Infinity Reference 3/4" tweeters, and installing Infinity 3/4" tweeters in the rear doors. My subwoofer isn't an issue. I now have 8 speakers to power.
What I am planning is to power the 6x8s with an additional amplifier, and to power the tweeters with the factory amplifier door channels. I have read that the factory amp puts out about 15w per channel, which seems sufficient for the tweeters. The tweeters all came with inline filters.
Here's the rub. Whether I use a line out converter or the high level input, I will need to tap into my rear door speaker lines. Can the factory rear channels be used to power the rear tweeters and send signal to the amplifier at the same time?
Thanks so much!
727
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
739
841
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
JakeJB
JakeJB
Utah
JakeJB
chipss36
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
