is 200 amps sufficient?
stockgp
i need to know if a 200 amp alt will be enough to power everything i'll be running.
head unit will be a clarion hxd10.
up front, nothing big. probably an aura mr675h 6 channel and 3 was active components.
for sub duty i'll have an elemental designs spv.2. however, it's currently being reconed by woofercooker for dual 1 ohm coils.
power to the sub will come from an american bass vfl 150.1.
this is where i'm iffy. i'll be running the amp at .5 ohm load. i also want to get an external voltage regulator for my alt to run at 16v.
i'll be doing the big three in 4/0 welding cable, as well as my power and ground wire.
i already got a quote from mechman alts for a 200 amp and external regulator. he told me it's not wise to go higher than that since my motor (olds 307) is v belt driven.
so, is 200 amps going to be enough?
oh, my bad. up front is an everstart maxx deep cycle. i forget the specifics on it. out back is the same, with a 205 minute reserve capacity. forget the other specs opn it as well. i can get them if they are vital.
both batteries were made by exxide before everstart switched suppliers
stockgp
stockgp
weirton, west virginia
stockgp
