Decado2
I did do a search, I do know you are supposed to reverse wire the inverted sub. My question is, should I reverse the rubber gasket or leave it on as is.
I figured, it would seal better if I reverse the gasket as that side is meant to be against the baffel.
I am inverting one of my subs because for whatever reason, I can't get it mounted flush when I put it in normal, the gasket keeps rolling off.
The sub was actually stuck in the box after the gasket got jammed in there, I had to puul the box out, drag it in the house and flip it upside down and lift it up and bang it on the floor multiple times to finaly get the sub out.
Was not easy considering each sub weighs around 50 lbs plus the 75 lbs box //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif .
