inverted subs
If the box is a sealed box and you invert it. then you need to switch to 180 degree phase. If it is ported You shouldnt need to. but listen to both and see what you like best //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
if your running more than one sub, and one's normal and the other inverted. just reverse the polarity on the inverted sub and leave everything else normal. if they are both inverted or u are just using one. leave it normall, then reverse it. see witch one sounds the best.
kingisback06
kingisback06
michigan
rollerdj
