Inverse functions?
I'm taking class online... stuck on a problem, chapter didn't cover it too well.
Given f(x)=3x+4
1. Is f(x) a function? Why or why not?
2. Find f -1(x).
Is f -1(x) a function? Why or why not?
I understand the inverse function of (0,1) would be (1,0), etc. but how do I solve those questions? I'm asking for someone to teach me, not asking for someone to do my classwork.
Thanks!
IIRC, that question is asking you to do the "vertical line test" to determine whether something's a function or not. The idea being, for each unique value of X you put in, you get one value of Y back. If you have something that a vertical line will pass through twice, you have two values of Y for a given X.
So the answer to one would be yes, the answer to the second would be no.
Not sure if that's what they want...
1. f(x) is a continous function because for any value of x there is a y value (example 3(2)+4=10 x is 2 y is 10
2. im not sure if this is correct but its my guess....
f(x) is the same as y. so f(x)=3x+4 is the same as y=3x+4 (the equation of a line)
if you switch x and y you get x=3y+4.... solving for y you get y = (x-4)/3
which 3.) should still be a function
not 100% positive but hope that helps
Eh, never did too well in precal anyway...
Somebody want to help me calculate adjusted exponential smoothing values for some data?
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Tiger: Maybe I'm reading into it to much? From what you put down, I still can't tell if it's a function or not... mind explaining to a math n00b?
yes its still a function y=(x-4)/3 graph that you will see its just a diagonal line slope of 1/3 y interecept of -4/3 therefore it passes the vertical line test. got a graphing calculator or have to plot points by hand?
AH, again, owned by not graphing.
I have a TI-89 Titanium in front of me... doh
Thanks guys //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
JimJ is right for the second part. You use the vertical line test to make sure its a function. Basically, you take a plot and if you can draw a line veritcally through the plot and it only passed through it once, its a function.
To tell if its a function, graph it (use a calculator) and see if it passes the vertical line test. If a line going vertical only intersects the function at one place, its a function. If at ANY point on the graph it intersects at two points, it fails the test.
Tiger just told you how to determine the inverse function per your thread topic.
*edit* I'm to slow.
ah i have the ti 89 titanium also... actually dont like it very much. liked the 83 more for graphing. untill i got to calc I II and III... 89 does derivatives and intergrals FTW so if you have to go any further in math keep the 89
Kenny Pollock
drag it!
Kenny Pollock
Hollywood, Florida Low: Yes
saj21187
vegang
vegang
