Sold Introducing True Bass solutions
DS Autosports
I LIKE SOUND!!!
I'm looking to spread the word about True Bass Solutions. To do so I'm selling them for next to nothing:eek:. I guarantee you'll love the quality and sound. Each sub is made by hand here in the USA by Dana Audio out of Tennessee. Message me if you have any questions or to place an order.
Video of the 2nd gen in action http://www.realmofexcursion.com/videos/TrueBass/ultimate8.1.wmv
Ultra 8's are rated for 250rms and 2K burps up to 3 sec, dual 2 and dual 4 available. Specs are as followed
Re = 3.4298 ohms
Fs = 37.3410 Hz
Zmax = 46.4751 ohms
Qes = 0.3413
Qms = 4.2834
Qts = 0.3161
Le = 2.2975 mH (at 1 kHz)
Diam = 155.0000 mm ( 6.1024 in )
Sd =18869.1914 mm^2( 29.2473 in^2)
Vas = 10.5085 L ( 0.3711 ft^3)
BL = 14.3582 N/A
Mms = 87.4380 g
Cms = 207.7628 uM/N
Kms = 4813.1816 N/M
Rms = 4.7893 R mechanical
Efficiency = 0.1506 %
Sensitivity= 83.7971 dB @1W/1m
Ultra 10's are D4 only and rated for 600rms and 3K burps up to 3sec, specs are as follows
Re = 6.2638 ohms
Fs = 34.4071 Hz
Zmax = 139.8793 ohms
Qes = 0.2495
Qms = 5.3222
Qts = 0.2383
Le = 4.1471 mH (at 1 kHz)
Diam = 206.3750 mm ( 8.1250 in )
Sd =33450.6109 mm^2( 51.8486 in^2)
Vas = 29.1322 L ( 1.0288 ft^3)
BL = 25.1720 N/A
Mms = 116.7464 g
Cms = 183.2737 uM/N
Kms = 5456.3213 N/M
Rms = 4.7422 R mechanical
Efficiency = 0.4469 %
Sensitivity= 88.5199 dB @1W/1m
Sensitivity= 89.5824 dB @2.83Vrms/1m
8's sound good in enclosures from .7 - 1cubic ft tuned from 33-40Hz
10's sound good in 1-1.5 cubic ft tuned from 32-35Hz
They will not work in sealed enclosures, or 4th order BP, Ported and 6th order only for decent sounding applications.
Any member that has one of these subs; feel free to let everyone know what they are missing. Thanks;)
Shouts out to Audio_phil for the "accurate" specs
Pictures of your products will probably be requested. Most people aren't going to buy anything without at least seeing what it looks like.
Just a thought.
EDIT: Saw a blurry video that was linked on Realm Of Excursion. Still want to see some nice, clean pics...
I'm looking for an 8", and a quick google search leads me to believe that these guys might just make a nice one.
Sure would like to see one. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
yeah... http://www.realmofexcursion.com/videos/TrueBass/ultimate8.1.wmv
True Bass Solutions 8
Diameter: 8.375” (213mm)
Mounting Hole: 7.25” (184mm)
Depth: 5.625” (143mm)
Weight: 10 lbs (4.5 kg)
Basket: 4 leg Cast Venezuela
Screw Pattern: Standard 8 Hole
Cone: Pulp Base with Poly Dish
Surround: 1.125” (29mm) Foam Half Roll
Spider: 6” (152mm) Phenol Treated Cloth
Arrangement: 5 roll Linear
Voice Coil: (2) 3.7 ohm DCR Round Copper
Diameter: 2” (51mm)
Magnet: (2) 5.25”x.75” (133x19mm) Slugs
Top Plate: 5”x.375” (127x9.5mm)
Back Plate: 5”x.375” (108x9.5mm)
Back Plate Bump Out: None
Terminals: Male Spade Posts
no newb...they are friends...and that is phils own equipment
and to the op...I can't believe that it took you this long to get here...I'm guessing phil told ya
If they are friends, that makes it even worse //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif That just means competing with friends for sales. Easy way to lose a friend if you ask me. //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Also, OP, are you selling the 6.5 inch ones too?
I am interested man. send me a message with some pics and full specs of everything that you carry. also what each sub can take daily (not rms) and what your box size and tunning recommendations are, and any other info would be great. also picked up prices.
A pair would be 2 ohms and to get them as loud as they could be would be around 1 cube per @ 40Hz and would allow about 400 watts rms per sub. I run 1 in .8 @ 33Hz with 600rms daily and it's took it for almost a year now without missing a beat. As long as you've got 600rms @ 2 ohms you'll be blowing peoples mind that it's just 8's. I did 141dB at the kick @ 44Hz with 1 in 1 cube @ 40Hz with a 1600rms burp, they are rated for 2Kw for 3 sec for burp, 250 rms (very very conservative)
This is what audio_phill told me about what I am guessing are the line of 8s this guy is selling.
I'm only selling the 8's and 10's
DS Autosports
I LIKE SOUND!!!
DS Autosports
BFN, NC
Twistid
