installing tweeters
tgraham09
im thinking about installing tweeters in my corolla. check my sig for my setup. the problem is the type r's are full range speakers and my corolla doesnt have factory tweeters. how would i install aftermarket tweeters in my car? can it even be done with my type-r's?
The type r coax-mid & tweeter are meant yo stay together
if you want the tweeter to be placed in the dash or door or where ever you might have to buy a new comp set, which will allow you to pace the tweeter from the mid
Well, technically, you can remove the coaxial tweeter... And relocate it... But you won't have the necessary mounts for it.
You can buy aftermarket stand alone tweeters that can be installed in the a pillars or other common locations. Pioneer sells a set for under a hundred bucks.
I wouldn't want coaxial door tweeters and dash tweeters at the same time. I would disconnect the coaxial tweeters.
Your best bet is a component set, as suggested.
If you are using just the radio.. What Radio? You may need to attach a ground wire from the radio chassis to a solid dash bar blot cleaned off for...
There are a couple that SMD has tested, around $20.00 that should take the wattage from most any HU. If you are tapping into the speaker wires...
tgraham09
tgraham09
Linesville, PA
keep_hope_alive
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
