Installing Soon Need Help
you need a dash kit. RCA wires. ground wire. sub box?..ha. remote wire ( between headunit and amp). i recommend mounting the amp to something so it doesn't have freedom to move around corners. so, drill + screws. if the amp has holes for them.
Yeah I do need a box still and haven't found a place or builder. Anyone know where to get security screws? How many do you think I should buy?
Install will be in 02 reg cab chevy silverado.
The dashkits I have heard of are Schosche(sp?) is there any other brands I should look into?
Do the dashkits come with the ground wire/remote wire or are these separate? Quality RCA wires?
Should I mount the amp on the back rear wall hanging or keep it on the floor behind seat flat on the ground? You think this is going to depend on box location and most likely things I should be discussing with my installer? All help appreciated
Speaker wire is going from your amp to your sub to power it.. It doesn't have to be very big 8 gauge at most but that also is never really needed. Get some 12 gauge, get about 10' for safe measures to wire your sub and your amp.. Also RCA's are from your HEadunit to the Amp a long with the Remote wire. Knukonceptz.com sells kit with all the needed components for an install..
Thanks maxi for the clarification I appreciate all the helpful replies people.....I'm slowly trying to get into the car audio scene with the assistance from all of you on the forum.
whitechevy
whitechevy
Otown
whitechevy
BP1Fanatic
BP1Fanatic
