installing QUESTIONS
alexleon86
Benz
I am having problems installing my two batteries to my isolater that is a 200 amp stinger. I got a kinetik 2400 has the main batterie source and a yellow top optima has the secound. Both of this batteries are in the back of the trunk next to each other. instructions on how to install this?
because i was having dim problems and i recently but this kinetik batt and i dont want to kill it quickly cause it cost me an arm and a leg to buy. Iam pushing 2,500 watts
lol, and isolater is used to switch between batterys. Pretty much if you gonna be bumping with the car off for a long time. In your application, and with about 98 percent of people on here wire them parallel. As do I and I have 3000rms, no sweat
like i had and,, isolateor, wen my amp was drawing power wen everything was off,, so this is the order it went in
front battery, power wire, isolator,power wire, amp, the isoltor as 2 big conntacts kinda like and in and a out, a small grond termanal,, and an ignition termanal,, that you hook up to something that only works wen the ingnition is on or the car is running, this makes the contacts in side close, making a path for the power to flow
like i had and,, isolateor, wen my amp was drawing power wen everything was off,, so this is the order it went infront battery, power wire, isolator,power wire, amp, the isoltor as 2 big conntacts kinda like and in and a out, a small grond termanal,, and an ignition termanal,, that you hook up to something that only works wen the ingnition is on or the car is running, this makes the contacts in side close, making a path for the power to flow
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif:confused:
i think i just lost IQ points
alexleon86
Benz
alexleon86
salinas Ca
funkyab
