installing amp
1. run power wires - leave fuse out until last!
2. connect ground wire to chasis
3. Run RCA's and remote wire from HU to amp - do not connect RCA's yet
4. Connect remote wire
5. connect ground wire
6. connect power wire
7. run speaker wire/connect to amp
8. Connect RCA's
9. put in fuse
Make sure you scrape your grounding spot free of paint and connect it sturdilly.
Also make sure that all the wires are attached firmly so they don't short out
That website up there is good too, also there is good info on http://www.bcae1.com
1. run power wires - leave fuse out until last!2. connect ground wire to chasis
8. Connect RCA's
9. put in fuse
Disconnect the negitive terminal on your car first (battery)
almo181
Juggalo
almo181
Sasktoon (been there for 2 months)
almo181
