installing a switch on my subs - how?
eisenhower
My ascendant audio atlas has adjustable qts depending on wether or not there is a jumper cable between 2 terminals.
on high qts, its gets really loud but sounds poopy, on low qts it sounds incredible, but loses output.
I have seen people install a switch on the terminal to change the qts from outside the box. What do I need to do this, and how do I do it? Thanks.
A high current automotive switch will be fine. Take how many watts / volts you're running and then get a switch with the amperage that is over or right on that number.
So if you're running 400w / 14.4v = 27A
eisenhower
eisenhower
motown
Shinobi
