Installing a Sub without Sub output on Head Unit?
I want to get another headunit but it doesnt have a sub output. It has 4 audio outputs RCA (Front and Rear, Left and Right) and my sub requires 2 RCA Left and Right channels. I will be using the built in amp to power my car speakers so this wont be a problem. Can i use the audio outputs (RCAs) e.g. the 2 front left and right to send the signal to my subs amplifier. It has a crossover as i tested this by using a 3.5mm jack to 2 RCAs from my ipod and it only produced the bass from my songs. So, can i use the Front RCA's (Left and Right channels) to send signal to my amp? or will the signal not be powerful enough? As from experiance, its not a very high output as if you connect a speaker thats not running from an amp its very quite. Does this matter as the sub amp will amplify it? But if the signal sound is low, then the sub wont be very loud?
How you understand what i mean?
Basicly, i want to run the sub amp from left and right channels audio outputs on head unit and my sub amp requires 2 RCAs (left and right) but will the volume of the signal coming from the RCAs be enough to use fully power of the sub?
Thanks.
check the voltage output of your head unit, match your sub amp to that. Set your gains and filters/x-overs correctly (seach on here there are threads about that stuff). hope this helps. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif A signal is just that a signal there isnt a difference to which red and white you plug it to. The only way it would matter is if your HU has a sepecific sub output for extra comtrols or something.
The main difference will be that your h/u will not provide the proper crossover funtions for your subwoofer system, and you will have to use the xover system from your amplifier or signal processor.
Ash 306
Ash 306
Ludlow, Shropshire
audioholic
AJ (ACE)
    Jun 28, 2026
