Installing a 4 Channel today..what do i need??
lionel2
PA
I will be getting my 4 channel via UPS today..and i wanna install it what things do i need..i have a mono amp installed in my SUV...do i need a dual amp kit cause it has all the things i need..or just buy them individually??..i stick with RF wires..so i wanna go with that brand...and i need 4 guage all the way through..here what i think i need:
1.Speaker wires more than 30ft
2. 2 sets of RCA cables 17 ft each
3. Distro block...not sure about this..but i want 4 gauge in and 2 4 guage out..do i get a 1/0 in and 2 4 guage out??
4. Fuses...60A and a 40A
5. new fuse for under the hood 100A
6. power and ground 4 guage wiring
7. remote wire
I think thats it..if i forgot something let me know...any suggestions on the distro block let me know that part i am not sure of..thanks
8 guage will be fine from block to amps??..that make sense about remote wire from 4 channel to mono...just a signal wires not much current..fuses..100A under the hood is right?? 60+40=100A...fuse according to fuse rating
always go with the biggest wire you can, future upgrades are easy that way, if you can, run 0 guage to the distro and 4 or 2 guage to the amps.
yeah i have a mono sub amp installed with 4 guage wiring power and ground..dude at shop said to have 4 gauge to block then 8 guage to amps..cause they are smaller amps only 40 and 60A fuses he said i will be okay
dude at the shop makes money if you blow your chit up.
true..thats why i wanna go with all 4 guage...i hate 8 guage...so looks like i gotta buy a RF block somewhere...which one do i get..that does 4 gauge in and 2 4 guage out...do i have to get the 1/0 in and 2 4 guage out one??...thats the major problem i have...i need one that i can put a 60 and 40A fuses in...thanks
I agree...that if your doing this install and have the option just go with a 1/0 awg and be done with it. I myself have Stinger 1/0 to a distribution block with 3 4 awg outputs....because I run w/ 2 Alpine mono's and a Kenwood multi.... so 1 (1/0) input and 3 (4 awg) outputs.
since u already got one amp hooked up i would think just run a hot wire to the pos and grould the amp, and use line out on the first and run the rca to the in on the second amp
lionel2
lionel2
PA
dflw_99
