installing 2 batterys....
HOGHUNTERS
i have a red top for the front and a yellow for the back do i need any thing in between to regulate or do the batterys need to be the same .. it says in the manual for the yellow top when running batterys parrelell they should be same make model and age... or should i just put the yellow up front and elimanate the red top.. i have a serious dimming issue and its a new alternator 130 amp rated..
you should be fine just wiring them strait to each other. the reason for them saying they should be the same age make and model is because it will one of the batteries sit below its max charge when the car is off. this will reduce life of the batteries but i have seen many people do it and have never seen any problem.
HOGHUNTERS
HOGHUNTERS
MPLS MN
funkyab
Mike Mccabe
