installin 2 10" alpine type r's
so if its not 1ohm stable how should i wire it
Your only choices are 1 ohm or 4 ohms if you use both subs. You'd be wasting your time at 4 ohms. If you just wanted to use one sub you could wire it to 2 ohms. To get the most out of your subs you need a different amp. You need at least 1000 watts anyway for two R's and that amp is only rated at 500.
Yeah, I'd look for something 1ohm stable if you want to run both.
unless you want to run just one sub //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
so what amp would you prefer using and what would it cost i dont want to spend much cuz i have 4 more subs i want to try and hook up
Why do you want more subs? More subs = more power needed and electrical upgrades. $$$$
For just the 2 Type R's something like an Audioque 1200 for $250 would work well.
i got 2 12" alphasoniks 400 series would they work good with that amp and how would you wire them
I don't know much about them but they're 500 watts rms as well. Are yours dual 2 or dual 4 ohms?
PSW41212” ALPHA 400 SERIES SUBWOOFER
• Heavy Gauge Stamped Steel Chrome Plated “Alpha” Basket
• Motor Assembly Heat Sink
• High Rigidity Inverted Dome Mineral-Filled Composite Cone
• EPDM Surround for Enhanced Control at Extreme Temperatures
• Flat Progressive Rate Nomex® Damper w/ Spiral-Woven Leads
• 8-Gauge Lug-Lock Input Terminals
• Rated at 500 Watts RMS
• 91dB Efficiency
• Frequency Response of 25Hz to 500Hz
• 46 oz. Double-Stacked Magnet
• Dual 4-ohm 2” Voice Coils
• Mounting Dimensions —
Depth: 6”
Through Hole: 11 1/8”
Diameter: 12 7/8”
lancer06
lancer06
Louisville, Kentucky
BobbyDD
