Hi.
I know that when determining the output voltage you use RMS x OHMS then the SQ.ROOT to get volts. However, do you just simply take the RMS rating that the company gives? I mean, what if the amp is underrated and puts out more RMS watts then is listed on the specifications?? In that case, it would change the total result
Does it matter that much?
Just curious Thanks!
