Input on Stetsom 10ks
Great amps. Just read a comparison of the 7k2d and a SD8000.1 and the stetsom was a tad bit louder. I know your not asking about the 7k2d but the 10k is the same amp just can be ran at a higher voltage. Have seen results of 13,000 watts out of these amps also.
OP.... I think you're coming on to the wrong forum asking this particular question.
now if it was about something like "dude should I bang this chick or what" ...then I'd say you're going to get appropriate replies.. but you can be assured that you will not get a "reliable" answer to your question on here..
you know where to go... TERMPRO.....
end thread
I frequent Termpro...they have a tendency to bore me over there...they have no flair or pizaz.
I'll give you the pizaz part //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
but if you're going to base your decision on the "opinions" and I use that term very loosely of the people on here then you're in trouble //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh:
I know that is not the case of course and I figure this to be more of a "let me f$ck around thread" You're a very educated competitor and figure you to have pretty much made up your mind on whats going into the Toyota.
Dumped...I have made my mind up, I just havent pulled the trigger yet. I find that alot of forums are biased. I see a little of everything over here thats why I asked.
Im sure no matter where I go some jacka$$ will make some crazy statement. But there are actually some very reliable people here as well.
Was 0.16 louder because the SD8000 was completely clipped, delivering 15kW... also was a normal SD8000 against a 16V modified stetsom
The 10k will do more than the 72k over 16 volts, but they are indeed very similar
Lovely amps, cant think of any better "10"k amps on the market for the price, other than the Sd's..
Im sure if the amp was putting out 15kw he would of posted that. Why is it everytime you talk about your amps they magically go up in power?
astrolade
sixftjap
astrolade
Macon, GA
Grinder1989
