Infinity Reference 860W in SMALL box
nathan909
So I built a sealed box, i was super tight on space. The box ended up being .27cf inside (not excluding any space the sub takes up if that matters)
The specs call for a .35cf box. I haven’t installed the speaker into the box, but with it being smaller than the specs will polly fill help? how much?? Any suggestions???
Also the magnet is like 1/8" from touching the bottom of the box (it fires up). is that a problem? should i place a small spacer between the magnet and the bottom of box?? Any suggestions???
It should be fine. Qtc of that box is .779, will drop a little with some fill.
It would be better to give the pole vent more space but I think it might be OK.
Rule of thumb is 1 lb. per cubic foot. So .27 lbs. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
4.3 oz... so about 1/3 of that bag.
Unless of course you have to pack it in. You don't want it to be dense, ruins the whole point.
Only reason I say this is because i'm having a hard time picturing both 4oz of pf and a .27 cuft box. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
nathan909
nathan909
Murrieta CA
Ray21
