Infinity Reference 1230w vs Pioneer
-JJ-
Which of these subs you would recommend, considering that my care is Audi A4 sedan, and the sub will be in a box (back in the trunk next to wall; behind the back seat)
Current Amplifier - Kenwood KAC-7201
800 Watts max power
150 Watts x 2 max (4 ohms) RMS
460 Watts x 1 (4 ohms) RMS
Frequency response 5Hz to 50kHz
Built in variable low pass filter (50 - 200Hz)
Built in variable high pass filter (50 - 200Hz)
Bridgeable
Speaker level input
Gold plated input & output terminals
Integral cooling fan
Complete with full fitting and operating guide
Here are the possible subs. I mostly listen to hip hop if it matters.
Subwoofer - Infinity Reference 1230w Specifications
Rec. Sealed Box Dims: 1.25 cu.ft.
Rec. Ported Box Dims: 2.00 cu.ft.
Free Air Usage: yes
Sensitivity: 92 dB
Frequency Response: 25-250 Hz
Recommended RMS Power: 300W
Peak Power Handling: 1200W
Impedance: 4 ohms subwoofer wiring options
or
Subwoofer - Pioneer TS-W1001C subwoofer
25cm - 800W
Front VCCS (Voice coil cooling system)
Foamed IMPP cone subwoofer with Dual layer Urethane edge, metal coated
3D-Cone Design with aluminium insert
4-Layer Copper round wire voice coils
Slit Aluminium voice coil bobbin
Long voice coil
Direct Bobbin mounted aluminium centre cap
Extended and vented pole yoke
Lead wires integrated large diameter Conex Damper with damper ring
Large strontium magnet
Magnetic Circuit Cover
Gold Plated Terminals
Specs:
Norminal input power: 400W
15-2,500 Hz, 86dB (1W/1m)
or
Pioneer TS-W1201C subwoofer
30cm - 1000W
Long voice coil
Specs:
Norminal input power: 500W
15-2,000 Hz, 88dB (1W/1m)
Which one would you recommend and why?!
i really couldn't tell ya performance wise which is better, but i know that sounddomain.com is selling 2 12" infinity reference for $150 shipped, and they are an authorized vendor
Hey man, I've got the refrences 12" 1230s and they kick pretty good ***. In a sealed box it gives great SQ and pretty good bump. I sell the pioneers and i don't like them that much to tell you. So i would have to say infinity all the way!
-JJ-
-JJ-
Latvia
hottchineseboy
NorthFramingham
    Jun 30, 2026
