infinity 1211a amp
its my car. dropping down to 11.6 volts when im pushing the amp hard. the HU is a pioneer DEH-p44 2 volt preout. i can get the gain about halfway up on the amp and it start to clip real bad. like is said in my other post my stock alt is rated at 110 amps and running a 1300watt amp is gonna pull close to 110 amps. my headlights dim real bad at night so its not my fault, the sub can do more but its the car not letting it.
you have settings messed on the amp or something not wired right. its not the car. my festiva had a 80 amp alt, no big 3, and i had a total of 130+ amps draw through my stereo, and had no problems minus severe dimming. dont blame the car, whats the sub level at on the hu? what gauge wire are you running for power? where is your ground going to? check your amp settings, and hu settings for filters that may be on when they should not be.
liftedcj7on44s
liftedcj7on44s
NC
liftedcj7on44s
