Incriminator Vs RE VS adire
Ha ha ha, you knew why i was asking. I told you im still considering it. and thats just the answer, I DID NOT WANT. ha ha, trying to make my decision harder than what it has to be...... But i wouldnt mind getting to RE MTs and putting a mojo on each.... Now thats a nice daily driver. lol.....but then again, i dont want to upgrade my alternator again. so 1 mojo is all i need
Is the Mojo modded? Run the MT at 1.4 daily and drop it to .35 for burps if it is //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
If not, get that ***** modded //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Dont see a XXX just up and folding under a MTX, modded or not. Im not sure which brand accepts poor gain adjustment. Ill look in to it and get back to you.
lets not forget about clipping due to gain hogging //content.invisioncic.com/y282845/emoticons/smash.gif.499e08a4a35ffaf54f4c8194fb8fe8ed.gif . If you dont care about sq then Death Penalty or MT is the way to go. I still want to hear a DP in person tho. They look hella strong and are rated at 1200 rms but I know they could probably handle 2000 daily.
lets not forget about clipping due to gain hogging . If you dont care about sq then Death Penalty or MT is the way to go. I still want to hear a DP in person tho. They look hella strong and are rated at 1200 rms but I know they could probably handle 2000 daily.
You do know that the DP is concidered a SQL driver not an all lot SPL'er. The DP has excelent SQ for how loud it is. Its not a farting cannon but it can shearly beat most of the fart cannons out there. DP = Loud and sound good while doing.
Jon
haha. how much would that be?
I really would like to run dual MT 15s for a daily install....Not sure if i can provide the 5 cubes each... Im pushing the 4 cubes each for my dp 15 install
can you provide the watts for 2 mt's??
assuming an excellent system...
200amp alt runnin max capacity @ 18v is still only 3600 watts, thats 1800 apeice and for an mt even that isnt all that much...most likley enough for daily driving though
I doubt it...thats why in a previous post i asked which one would get louder off of 1200W a piece between the MT15 and DP15. And that i didnt want to spend the time trying to upgrade my alternator again. to provide the juice to pump them accordingly. Thats why more than likely, i will be sticking with my DP15s install
yea i would also stick with the dp15s...i ran a single 15mt for a while with 1100watts 4cuft 30hz and it honestly barely moved, when i swapped only the sub out and switched it with my 15HC the hc destroyed it in spl and sq...and personaly i think the mt sounded like pure sh*t
least you got a 180amp alt though, thats nice, im still tryin to run everything off of 65amps lol...hoping to get a 200amp within a month though
Mr. Nipples
Pimp ***
Mr. Nipples
Grand Rapids
ngsm13
