Incriminator death row sub box design
buickv6
I am looking for any advice for box designs or where I can look? I have a pair of older version 12" 1500w death row subs with just the logo on them and I would like specs to build a box to fit in my ranger extended cab. I have emailed Nick at Incriminator Audio to see if the newer sub box specs on their site apply to my older version subs before I get too far with this. I am looking for an spl ported box, these subs have hit 146 in the car they had been in prior, I would like to see similar spl. I am also using an Incriminator IA20.1 amp rated 2800w at 1 ohm. I am thinking I want the subs and slot port(s) facing up and I only have a max of 13" deep x 21" tall x 48" long. I hope that's enough volume for both of these 12's?
Thanks,
Shane
Thanks,
Shane
Just to update my post, it looks like everything I need is on Incriminator web site as I missed it the first time. I will likely follow this for my build and based on my space limitations I will probably go for the "recommended volume" hope it will entertain 146 spl...
DR12Minimum VolumeRecommended VolumeMaximum Volume
SealedN/AN/AN/A
Ported2.00ft^32.50ft^33.00ft^3
Port Opening28in^2 (2.25" x 12.50")35in^2 (2.80" x 12.50")42in^2 (3.38" x 12.50")
Port Length26.50"25.50"25.00"
Port Tuning35hz35hz35hz
Port Displacement0.43ft^30.52ft^30.61ft^3
Sub Displacement0.15ft^30.15ft^30.15ft^3
Subsonic Filter32hz - Setting32hz - Setting32hz - Setting
Low Pass Filter80hz - Setting80hz - Setting80hz - Setting
buickv6
buickv6
Canada
buickv6
