joshpoints
If you wire a dual 2 ohm voice coil with only one voicecoil being used will it be obvious soundwise (will it sound terrible making it obvious)? It's wired to a bridged amp 400X1 at 4 ohms. Not 2 ohm stable.
Like the pic below. let's say you wire the positive and negative together on the same side of the sub and hook your amp up to the other voicecoil positive and negative on the other side (if that makes any sense), will it cause only one voicecoil to run with this kind of wiring?
