In or under the car?
jersyn82
Running 0ga wire and was wanting some advise on whether I should run it under the car? It looks cleaner but is it safe?
If I can I'd rather do this, I've already got 4ga running in the car .
If I get lucky I was hoping to go through a drain hole in my trunk.
Depends on if you run a few runs I would do under. As long as you make sure it cannot ground out.
If I ever go bigger I'll be running all my power wire under my truck.
And depends on we're amps/battery's are at.
What I'm saying run it were you want.
The amp is mounted to my back seat (keeping 4ga for amp mids/highs in the future). My car is a nissan sentra. It will just be one run but I think I'm going that route.
I've typically ran under my vehicals hard to fit 0 have thru the car. When I had my blazer I managed to run my wire through the actual frame of the car. Used the same run of wire for years in multiple cars
jersyn82
jersyn82
ohio
des343
