DidUHearThat?
Precious Bodily Fluids
It sounds like you had a loose ground connection and it cooked the cable at the connection. Cut it back till it's clean, scrape the burnt crap on the car back down to bear metal.
Use a meter to determine if you are reading voltage at the amp. You should see +12 volts and continuity to ground.
Ignore the cap. (except don't touch the terminals on the cap= shock hazard)
