In-dash DVD Install???
If you go into the settings and change backround there r actually some XXX wallpapers(my bad) on there too LOL I personally would cap off the speaker wires but it may not matter anyway
Yeah I noticed the pics:laugh:: Quick question, I tapped into the ignition fuse to power the deck. It only works in the on position. My previous deck worked in the acc position and cut off when the doors opened. I tried tapping in to the radio nav but that was constant power. Then, I tried tapping into the internal factory amp fuse. but that was constant power also. Which wire do I tap to get the amp to work in acc and cut off when the doors open? Thanks.
There is probably a series of relays that give you the on till door opens power. I wish I knew where to help you find it, but I just know how it is done in general. Where did the stock HU get power from? I wonder if part of the relay wiring was connected to the original HU and was not connected to your new HU.
My Kenwood deck is the last deck I had running in my set. A friend tapped 1 wire and the deck worked in acc and turned off when the door opened, just got to find that wire.
is this a serious topic??
if so ROFL
Dont be an ***...remember your younger days when you knew jack SH*T about install...everyone learns somewhere, Ive been a professional home theater/car audio installer for 6 years and I have no problem with ppl willing to learn, I get irritated with ppl that think they know everything and argue tho
stl_style
Registered User
stl_style
Around the corner
SSon22s
AJ (ACE)
    Jun 28, 2026
Mike Mccabe
    Jun 28, 2026
