Improve sound - 2000 Toyota Tacoma
halfstepdown88
I have a 2000 Toyota Tacoma 2-door with a cab. The sound system is just the factory stuff. I want to improve my sound so I'm looking to get new speakers (and a week ago I messed one of the speakers up just a tad turning it up too loud and really bassy stuff sounds bad out of it now).
I've heard that 5x7 is what I need, thats what i've been told in two stores and thats what audiovox.com says but infinitys website says that both my speakers are 6-1/2" with a depth of 2-3/4" here
http://www.mobiletoys.com/partners/infinity/v_details.asp?MAKE=48&MODEL=TACOMA&RECORD=6380&YEAR=2000
Crutchfield says 6-1/2 inch and crutchfield says I can fit a 6-3/4" in the rear speakers.
I am completely new to this stuff and don't really know what to look for that makes a speaker good.
here are some pictures of where my speakers are.
Speakers in the rear of my truck
Pen to show size I guess
Front Door speaker (how do you get to these?)
Also my friend's car has to get totaled and he has two amps now and said if they are still fine he could probably sell me one and I'll know sometime in a week. This would improve the sound of my speakers right? And should I also get a new head unit too? Thanks guys
I see this is your first post, so welcome to the forum! I will see what I can do to help you out. I will list some common ways to get better sound. Also, a budget would be helpful to us.
(I) Speakers
Speakers are separated into two main categories coaxles and components. Coaxles have on-board crossovers (control the frequency that is sent to each driver) and are built as one piece (the midrange and tweeter cannot be separated). The benefits of coaxles are they are cheaper, easier to install, and are satisfied by head unit power. The problem with them is they sound quality/volume are compromised. Components have external crossovers and the midrange and tweeter are separated. They are more expensive, generally more difficult to install and must be powered by an external amplifier. They do sound better though.
6.5" speakers are the preferred size. They have better midbass (60-200 Hz) output then smaller speakers and have better sound then oval shapes IMHO.
A pair of coaxles should run you around $50-100. A pair of components should run you from about $100 up.
(II) Subwoofer
Another way to get better sound is to run a subwoofer. This covers frequency ranges your midrange speakers cannot play. It will help add fullness and volume to your music. Subwoofers must be powered by an external amplifier. Also, they need an enclosure to operate. A common 10 or 12" woofer will need somewhere between .5 cu ft and 2 cu ft to operate properly. While we are on enclosures, I will briefly mention them too. There are ported and sealed enclosures. Ported will be louder and if tuned around 30Hz will have excellent sound quality. Sealed boxes are more simple and require less air space. Both can be made by you for $30 or $40 and if built properly will dramatically improve your subs performance.
A normal subwoofer will cost your between $100-300.
(III) External amplifiers
Amplifiers will help your setups sound in all regards. As mentioned above a subwoofer will require an external amplifier. I would also amplify your midrange speakers are well.
(IV) Head Unit (H/U)
An aftermarket H/U will definitely be better then your stock Toyota cd player. My family owns 4 Toyotas and each of them came with a sub-par cd player. I would upgrade that for sure.
(V) Other
There are many other ways to get better sound. I will briefly touch on some of them here.
(i) Sound deadening. If you want more out of your system, sound deadening is a must. Check out Raammat or Second Skin before you go out and by the expensive Dynamat.
(ii) Active processing. Another way to get better sound out of your component set. This is a more advanced technique though.
(iii)Good installation. Yes, I saved this one for last because its the most important part of your sound system. Lots of money will buy you great equipment but won't buy you a great sound system. Spend lots of time reading about how to properly install and tune your stuff.
So where does that huge post leave you? If I were you I would add things in the following order
1: New head unit. I really do dislike Toyota cd players and would recommend a new one. Search the classifieds on the classifieds forum. H/U tend to sell for very cheap on here as compared to an audio store. I would spend about ~150 for a used one.
2: Component set for the front. There are many different sets out there. Go to a store and listen for yourself. Bring a notepad and record what ones your like and dislike. Don't purchase your speakers without listening to them first! I would spend ~200-300 new (although used isn't bad).
3: Component amplifier. I would choose something that provides around 100 watts RMS into 2 channels. ~100 used.
4: Subwoofer with amp. If your budget is small go for one or two 8" (or your Toyota is a single cab). ~100-200 (pair). Amplifier ~100 used.
5: Sound deadening. Purchase ~10-20 sq feet if you are on a budget or a whole roll if you aren't. Deaden the doors (there's a sticky about it)
6: Coaxles for the rear speakers. Run them off head unit power. I would much rather purchase a good set of components and leave the rear speakers stock over purchasing two okay speakers for the front and back.
Well...that turned out to be quite long. I hope it helps you out. I would do 1-4 of the above steps for sure (and 5 would good too).
My head unit is this massive cd player and tape player i could take a picture of it if you want. So buying a head unit first would be more important than new speakers?
And why are front speakers better and for the component sets are they hard to install? I don't even know how to access the speakers in the door, should I pay for installation or do it myself? And I would need to purchase an amplifier for it too.
I guess i'll just start out here. Thanks that was a really helpful post.
I drive the same car and the sizes crutchfield has are correct. However, on the front doors you should replace the plastic baffles with wood ones since they are stronger. Follow the tips in this guide http://www.caraudio.com/forum/showthread.php?t=95925
To get to the front doors, first take off the window sills. Pop off the push-type retainer on the end nearest the door hinge.
Pull the bottom of the window sill horizontally toward you and then pull it upward.
Pop off the 2 caps on the underside of the armrest and unscrew the 2 screws deep inside.
Unscrew the screw in the door handle.
Push the handle toward the door hinge (horizontally with the door) to pop it out.
Pop off the panel with the door lock and window control buttons and detach all of the wires.
There are retainers near the edges of the backside of the doorpanel (that attach the doorpanel to the door), which you can either just pull off or you can buy the doorpanel removal tool.
Pull off the door panel and pull the door handle through the hole in the doorpanel.
I never liked rear speakers in this particular vehicle, but that's just me. The cabin was small enough that it didn't necessitate them.
Yeah, I know what the cd player looks like. Both my parents Camery and Sienna cd players have horrible skipping issues. If yours doesn't have this problem then I would move it down the list. Also, just fyi, if you do replace the head unit you can purchase a piece to fill up the space created by the smaller head unit.
There are two groups of people on this forum. Those who like rear fill (speakers behind the listener) and people who abhor it. They both have their reasons for or against it so I will let you read about that one on your own if you want more info. Here are some reasons for better front speakers:
(1) Most people have limited funds and its better to get 1 good set of speakers then two sets of crappy ones.
(2) Most people prefer the music coming from the front (much like you are at a concert) vs behind you.
(3) Sound bounces and reflects. If you run huge rear speakers and stock front speakers the sound that finally reaches your ears has reflected many times over. It will have cancellation (quiet frequencies or overly loud ones) and more distortion.
(4) Many more. Honestly, I wouldn't worry about your rear speakers at the moment. Keep the stock and run them off of head unit power.
They are harder to install because they normally have three parts: a crossover, a midrange driver and a tweeter (for instance here). That means you have to mount 3 pieces instead of 1 (standard coaxle here). Also, as drivers are physically separated it is more difficult to set up the sound stage (basically when you set down and close your eyes it sounds like the vocals are in the middle, the violin is off to the left, the bass guitar is on the right. Its kindof hard to explain here, but if you do some reading you should get the basic idea). With all that said, components are the way to go if you want better sound.
That depends on how much money you have and what type of person you are. A typical installation will be expensive (for me far too expensive). I prefer to read up then install it myself correctly and save myself a few bucks. Also, if you hate working on stuff then pay somebody to do it for you. There are quite a few resources available to you here on this forum though (stickies are there for a reason). You should be able to find examples on how to do basically anything.
It depends on what you are wanting out of your system. If you want something that will sound okay and have only 200 bucks then no. BUT...you will hear a huge difference when you amplify after market speakers.
Hope that helps out a little bit. If you have more questions keep asking...
Whats a piece? haha and I don't have any skipping issues should I get speakers first then?
Yeah it bugs me when I'm in the backseat of my friends car and all the sound is just coming from behind me, so I'll replace the front speakers and not care about the rear for at least a while.
Is infinity good? I've heard its good, should I look around for a good deal for infinity component system? And do I need to make sure they have the right RMS or something so it will work with an amplifier? This stuff is very interesting but pretty hard to get the hang of when you are just starting out, thanks for all your help guys //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
EDIT: Oh yeah I don't think I'll be able to get a sub as if I got one wouldn't I have to sacrifice less people being able to fit in the back?
The "piece" is basically a plastic cover that covers up the hole in your dash. If you don't have any skipping issues then I would go with some speakers/amp now then upgrade later if you want.
Infinity is good if you are buying their $100-150 stuff. Above that and you can get better for less. A brand you might want to check into is Rainbow. For the money they are hard to beat. Also, if you do a search for Rainbow you will stumble upon other good brands.
Its not necessary to match the output/power handling of your amplifier and speakers when you are buying your equipment. It is important that you set your gains properly though. When you go to install read up on the sticky. It will help you from frying your speakers by sending them a clipped signal.
It might be possible to build a box that fits under your seat? Look into some AA Assassin 8". They are cheap and require very little airspace. Perhaps you can find an install/enclosure where somebody has done this before. I doubt its that uncommon.
Gonna have a hard time with under-seat enclosures without using fiberglass in a tacoma. Even then you're gonna need pretty shallow subs. I managed to fit ~.3 cube enclosures for 8"s in the holes where the rear speakers are but don't expect anything spectacular as far as output goes.
man i got a 99 ext cab. i had to go with door pods because the stupid window component was in the way.
JAZN: got some final pics?
here's a sexy pic //content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif
Not sure if your looking for a sub later on, but I had a 2000 Tacoma with a 10in JLw3 in a stealthbox in the rear cab that sounded phenomenal. I had the amp under the passenger seat. They are a little pricey, but I see them every once in a while on Ebay---So if your ever looking for a sub---worth a look
Dave
halfstepdown88
halfstepdown88
UTAH
halfstepdown88
