imperium Audio Designs "Reign" series stocked and shipping!!
  • 6
g6ryder
The following pictures are a few customer's subwoofers that pictured before they went out. Only a few of the available dustcap colors that are available are pictured. We have red, blue, black, white, yellow all available.
All prices and specifications can be found:
Imperium Audio Designs - Home
Email: stephen@imperiumaudiodesigns.com
Can take CC over the phone as well.
T/S Parameters: No breakin D4 in series
fs 32hz
qms 7.2
vas .923 ft^3
mms 334g
revc 7.8 ohm (in series)
qes .63
spl 83.3 db 1w1m
qts .58
le 3.9 mH
bl 28.89 TM*
15"
fs 32 hz
qms 7.36
vas 2 .5 ft^3
mms 378g
revc 7.6 ohms (series)
qes .69
spl 87.2 db 1w1m
qts .63
le 3.8 mH
bl 28.92*Tm
15"
12"
Currently about sold out of both 15s and 12s. We have enough parts for 2-15s and 6-12s. The rest of our parts to get stocked back up will be im this coming week.
You can order at imperiumaudiodesigns.com site is updated with production pictures.
Curious about the very high Qes indicating a weak magnetic charge. Do you outsource this, or are you doing it in-house?
Here*is the T/S for the reign 12" d4's in series no break in,*
fs 32hz
qms 7.2
vas .923 ft^3
mms 334g
qes .63
spl 83.3 db 1w1m
qts .58
le 3.9 mH
bl 28.89 TM*
15"
fs 32 hz
qms 7.36
vas 2 .5 ft^3
mms 378g
qes .69
spl 87.2 db 1w1m
qts .63
le 3.8 mH
bl 28.92*Tm
Oh, much nicer. I was looking at some other T/S numbers you had up in a different thread, something like a Qes of .8 and 1.01 in a couple of drivers, along with a really high Fs and realtively low BL product. Not a good combination for a subwoofer. Just wondered if you had a problem with magnet charging. These numbers are looking a lot better.
Yes we made some changes thay ended up spec'ing real nice
While current stock is very low, we should be picking up are LARGE shipment of parts sometime tomorrow. We can still build a few subwoofers of each size until then, if needed.
g6ryder
g6ryder
Claremore, OK
g6ryder
audiobaun
    May 19, 2024
    May 19, 2024
