Impedance rise measurement
If you have 15-30k you can get yourself a B&K setup that will provide very accurate results for what you are after.
OR...
You can do things on the cheap by connecting an amp to the outputs of your computer sound card and running your speaker from the amp with a 100 Ohm resistor in series with it. Download sine wave generator software or WinISD Pro which has a generator built in. You can then measure the voltage across the resistor with a multimeter, as you sweep the different frequencies. This will give you an indication of the impedance peak. This method is as accurate as the response curve of your sound card, amp, and the error correction of your meter.
Cabin_Pressure
yeah, it'll do
Cabin_Pressure
USA
mrogowski
