Image Dynamics XS and CXS v.2 comp sets.
James Bang
Hand/Ear Coordination
So after installing a set of XS component set for someone, I found out something interesting. The passive network doesn't do anything to the mids. It's basically just for the tweets. Most comps has a low pass filter for the mids, but these don't. The mids naturally roll off around 4-5khz.
The passive xover for these two sets are almost identical, except that the CXS v.2 compensates for the sensitivity difference between the mids.
So... I was thinking, the mids can hooked up to an amp alone w/o the tweets and all you need to do is use the amp's/HU's high pass filter for them and let the top end roll off on their own. Then, on two separate channels, the tweets can be hooked up to the passive xover, and it'll basically be like bi-amping the set. By doing so, you can separately adjust the levels between the mids and tweets, or you can bridge the mids and get more POWA to them.
Cool beans. I'd surely like to try the CX v.2 mids.
i had the oems running passive with about 75 watts to it and the tweet and....meh. then i ran them active with about 120 watts and these beasts came alive. Id imagine the cxs would be the same.
you mean you didn't know that james? it's been said over and over at the iD forum
My setup was set and completed before they came out, so I didn't research them and I stopped wh@ring their forum a while before that.
Oh yeah, I know Ill want to upgrade them I just dont know if Ill need to upgrade them. If a new amp that handles PCM gives me a noticeable improvement then Ill be able to wait for a while before upgrading speakers.
How powerfull is the midbass on these? I know it sounds idiotic to you SQ guys, but would they hang with a 3000 rms sub, that I probably play more around 2500 rms to? The XS set that is.
Some TS params and some calculations might help out here. Or your can the cool way and try to build 10 different enclosures for them //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Haha. Smart ***. I deserve it though.
Maybe I'll look into it, and see what would work well in a pod (sealed). I don't think I have enough room in my door to run what I want.
over the counter drug information fixtinhot
meridia diet pills
It may take four to six weeks for any noticeable change in body weight.
meridia online
Meridia is not an unmixed blessing; it has some potential side effects including fatigue, constipation, decrease of saliva inside mouth and sleeping disorder.
MERIDIA DRUG \ Order Meridia Without Prescription \ Buy Cheap Meridia \ Generic Meridia Sibutramine \ Meridia Weight Loss Medication \ Meridia Online \ Order Sibutramine \ Meridia Cost \ Sibutramine Medication \ Purchase Meridia \ Cheap Sibutramine \ - order sibutramine
Side effects of Meridia can be amplified if the user take alcohol.
Great info.
James Bang
James Bang
Maglite
