ID OEM 6.5 mid's 150w rms 4 ohm versions
basically in new condition. bought them a couple years back, but once i mounted them in the rear doors of my dodge ram they just werent going to work. so they have been in the garage since. no rips or tears in surrounds, work flawlessly
edit: SPECS
ID OEM Specs
overall dia 6.625"
mounting depth 3.125"
mounting dia 5.625"
magnet dia 4.5"
* Loudspeaker Measurement System
* LMS 4.3.0.300 九月-22-2001
* ©opyright 1993-2000 by LinearX Systems Inc
* ElectroMech Speaker Parameters *
* May 10, 2006 Wed 3:17 pm
* Library=ID公司样品.lib
* Reference Curve=A65P1-35-C
* Delta M/C Curve=+5g
* Method= Double Curve - Delta Mass
* Domain= FreeAir
* Model= LEAP
Revc= 3.200 Ohm
Fo= 62.796 Hz
Sd= 134.780 sqCM
Krm= 14.731m Ohm
Erm= 0.588
Kxm= 5.021m H
Exm= 0.771
Vas= 12.361 Ltr
Cms= 479.205u M/N
Mmd= 12.505 g
Mms= 13.405 g
BL= 5.884 TM
Qms= 6.974
Qes= 0.489
Qts= 0.457
Revc=3.2 ohm
Sd=134.780 sqcm
No=0.600%
SPL=89.840dB
Rms: 0.758
Re: 3.198ohm
Xmax: 6mm one way
$85 shipped
flat rate priority
edit: SPECS
ID OEM Specs
overall dia 6.625"
mounting dia 5.625"
magnet dia 4.5"
* Domain= FreeAir
* Model= LEAP
Revc= 3.200 Ohm
Fo= 62.796 Hz
Sd= 134.780 sqCM
Krm= 14.731m Ohm
Erm= 0.588
Kxm= 5.021m H
Exm= 0.771
Vas= 12.361 Ltr
Cms= 479.205u M/N
Mmd= 12.505 g
Mms= 13.405 g
BL= 5.884 TM
Qms= 6.974
Qes= 0.489
Qts= 0.457
Revc=3.2 ohm
Sd=134.780 sqcm
No=0.600%
SPL=89.840dB
Rms: 0.758
Re: 3.198ohm
Xmax: 6mm one way
$85 shipped
flat rate priority
