I'm Upgrading my car's Electrical Workings...
My electrical is giving me a headache. See if you can figure out if I wired and fused everything correctly
I would ground the amps to the rear battery and ground the rear battery twice. Good places
And you need to ground that alt somewhere. I have mine on the front battery
Why do you have 1/0 and four gauge wire going to your amp should all be the same size wire....
Especially if it has dual inputs
Ok, I'll put 2 runs of 1/0 power to the sub amp. using 2 250 amp fuses. That sub amp recommends 300 to 350 amp external fuse, so I'd have to somehow make the fuses for the sub amp equal to 350 amp?
bs199sg
bs199sg
United States
bs199sg
