If my alts 200 amps... fuse size?
silenkiller
What size fuses should I be using? I originally was figuring 150 amps for my inline fuse from battery to trunk battery, but that was before the HO alt upgrade. So do I go to 200 then? My distribution blocks can only take a max size of 150 amp fuses, sigh that will be an issue.
Last question guys, I promise //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
With a bigger alt you will allow more current to your amps. Although the power will be cleaner with the bigger alt your amp will draw the same. I would go ;
(My rule of thumb)
100amp =1000watts
200amp= 2000 watts
300amp =4000 watts
If your voltage is dropping below 12v these may pop any how.
silenkiller
silenkiller
zz
missinglink
