IDQ up-firing with port back
budahbuddy803
I was looking at the sticky box plans, do you guys think it would be ok to use the 2.75cuft @ 30hz box plans and build it as is except instead of having the sub and port face the same way mount the sub on the top of the box (upfiring) with the port on the front facing the back? I want to do this because i have a 15" and the front baffle is like 14.5in high but the top is 17.25in therefore i would be able to fit it on top but not on the front. Is it ok to have the IDQs upfiring with the port facing the back? I really want SQ i will build 2 seperate boxes for 2 IDQ15"s.
i personally would prefer to have the sub and the port on the same side of a box. with a few bucks someone can design you a box to your specs/needs
budahbuddy803
budahbuddy803
Aiken, SC
budahbuddy803
